Thread: Engine Lids: 1970 911S
    1970 S owners:
    I recently looked at a late 1970 911S (August birthday). Although restored, it was reputedly a 70,000 mile car. It had a steel lid and center panel.
    I have read that the 1970 S would have had an aluminum lid and center panel.
    Is it invariably the case that a 1970 should have the alloy bits?
    Thanks for your help.
    Oct 2005
    Minneapolis, MN
    I've seen '70 Ss with steel.......
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Senior Member Milou's Avatar
    Mar 2006
    Geneva
    Me too, the original lid on the 2.2S from 1971 was in steel and not aluminium. I guess it depended on available stock....
    Milou / Registry #884
    www.ecurielyford.com
    Nov 2003
    Sydney
    The 2.2S series should come with both an alloy engine lid and number plate panel.
    Steel panels could have been ordered as an option no doubt depending on the destination.
    After 35 years,well, all kind of events could have happened.
    From previous correspondence here,it seems that some of the ' 69Ss could have had these panels too.
    Cheers,
    Dennis .
    S Registry member 536
    Jun 2003
    Toronto
    I have owned my 70S for 29 years,it is also a late production car and it has a steel center panel and steel engine lid which I believe to be original.
    Rudy
    Alloy Lids for 70S?
    Thank you for the very helpful replies. It sounds like it could be the original equipment, albeit not the optimal specs for this car. Thanks again for the help.
  1. '68 engine lids--Thick body rib under grill or not?
    By Rotmilky in forum General Info
    Last Post: 08-03-2011, 01:23 PM
  2. TRE replica Alloy Engine lids
    By BOYER73S in forum Technical Info
    Last Post: 07-09-2010, 04:35 AM
  3. Targa Engine Lids
    Last Post: 11-15-2006, 06:43 PM
  4. Engine lids for 72S?
    By Longballa in forum General Info
    Last Post: 08-06-2006, 10:28 AM
  5. F/S 911S or 911R Aluminum Rear Deck Lids
    By kecho in forum For Sale: 911 Parts
    Last Post: 06-19-2006, 05:48 AM
