Results 1 to 7 of 7
Thread: pic of 70 S with 181 and thru grill lamps installed??
    Aug 2003
    Van Nuys, Ca
    anyone have a pic with both of these lamp set ups installed?
    Thanks!
    dave
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Senior Member tfmcmahon's Avatar
    Jul 2003
    Tucson,AZ
    What angle
    Here`s one on my 71T.If that`s what you need,I`ll get a different angle.
    Member:S Registry #864
    Aug 2003
    Van Nuys, Ca
    yes- that's it! wow that was fast- thanks, i would like to see more shots of it
    db
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    Jul 2003
    Tucson,AZ
    More
    Dave, Retirement has it`s advantages.I live in the garage! Here are some more,but not sure what you are after..Tom
    Aug 2003
    Van Nuys, Ca
    i have thru the grill fogs and a new set of the hellas - as pictured on your car and was curious on how the combo would look together
    Thank you!
    dave
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    One thing I noticed on your '71 T I have on my '71 T as well -- dual trunk lights. Not many cars have those -- my car came with the "S" options, so I assume that was part of the S upgrade on the car from the factory -- I was wondering if you have the S options on your car as well.
    Senior Member sweetE's Avatar
    Dec 2002
    Highlands Ranch, CO
    My 71 E also has the "dual lights".
    Dale Thero S Registry # 200
  1. Replies: 0
    Last Post: 03-09-2014, 11:38 AM
  2. Retractable belts installed
    By Aldo in forum General Info
    Last Post: 12-01-2013, 05:08 PM
  3. Replies: 15
    Last Post: 11-07-2012, 06:18 PM
  4. RS Speedo & Tacho Installed
    By Highfield in forum Technical Info
    Last Post: 12-06-2009, 08:49 PM
  5. TTG(Thru The Grill) Fog Lamps - Lamp Bracket Base
    By karlusmagnus in forum Technical Info
    Last Post: 01-30-2008, 03:39 PM
