Results 1 to 7 of 7
Thread: Rear quarter window rubber moulding fitting ?
    I am having a real hard time getting a piece of the rubber moulding seated in the window frame edge. I have tried working it from both sides and everything else I can think of. Is there some trick or method someone knows to get these on. The channel in the rubber that fits the inside of the frame is very narrow and I can't get it over the frame edge. It looks like it would just stretch over the edge, but it doesn't.
    Help!
    Scott
    Scott Marshall
    911 S Registry member#724
    1981 Porsche 911SC
    1993 Porsche 968 Clubsport
    1961 Abarth Record Monza, 1964 Abarth Simca 2000
    1962 Abarth 1000GT, 1964 Abarth 850TC Nurburgring
    The only way I have ever found it possible to fit the rear quarter window rubber easily is by using rubber grease in large amounts, otherwise its next to near impossible to get it in the correct position.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Oct 2004
    SW Suburbs of Chicago
    I found that I had to lube the rubber and slide it into the channel of the leading edge of the quarter window, really bending back the corner of the rubber in order to get it started,then the rest of the perimeter was easy to push in. The leading edge just will not push into the channel. Good luck
    Clyde and "EsGeht",
    What kind of grease did you use? Did you use a petroleum based grease or some kind of dry lubricant?
    Thanks for the help!
    Scott
    Scott Marshall
    1981 Porsche 911SC
    These things are a bite in the pants to say the least. I recommend several Warsteiners chilled to 43 degrees. Any colder and you will insult the Germans. Seriously use any greese but no WD-40 everything will slide in and out. Be prepared for lots of paper style cuts that feel great when mixed with lube. That's where the beer will save you.
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Liquid dish soap has always done the trick for me and leaves my hands oh so soft.
    1970 911S Targa
    On the road again soon.
    Thanks a bunch for the helpful replies. These moulding are sure tough to deal with, but grease did the trick. My only concern is that they might be prone to slip out of place with the grease in the grooves. The liquid soap sound like a good idea beacuse the lubricant would dry out leaving the rubber with good gripping properties on the metal frame.
    thanks again.
    Scott
    Scott Marshall
    1981 Porsche 911SC
  1. Replies: 1
    Last Post: 03-20-2014, 05:24 PM
  2. FS. NOS right rear quarter window, 68-77.
    By Burint in forum For Sale: 911 Parts
    Last Post: 06-04-2008, 07:55 PM
  3. rear quarter window installation
    By julerb in forum Technical Info
    Last Post: 04-14-2007, 08:46 AM
  4. Replies: 6
    Last Post: 11-17-2006, 06:34 AM
