Thread: Replacement door
    Replacement door
    A quick question, my 70 S is in need of a new door, the rust is severe on the door and I think it would be easier to replace then try and save this one. Unless there is some reason why I should save this one. I know most 911's use the same door, but are they all the same? I found a 80 SC door and another from an 84, and one from a 75. I realize that a targa or cab door won't work, but are any of these viable substitutes?
    1970 911 S Barnfind/Work in progress
    1976 911 S Ducktailed Targa with a 3.0 (I know...I know...mid year,but I love her too.)
    Can anybody help me out?
    I'm getting ready to buy the door of the 80 SC unless someone knows why I shouldn't.
    Anybody?
    Door replacement
    Any 911 door will work, coupe, targa, or cariolet. Any door made after 1975 is zinc galvinized to help prevent rust and the replacement door will have a crash beam in it. Your original door does not have the crash beam. I think the crash beam is a good thing. Hope this helps.
    All the best!
    Roger
    if you want to keep your interior original, the door pockets were only made from 69-73. the threaded mounts might not be there on newer doors.
    look before you buy. otherwise the door should fit just fine.
    bob
    bob moglia
    '72 E sunroof coupe
    door replacement
    All of the 70's and most of the 80's doors still have all the nutplates and holes for all of the early door pocket hardware.
    Roger
  1. Need help on door detent replacement for '73 RS
    By wolfturbo in forum Technical Info
    Last Post: 11-29-2015, 12:29 PM
  2. Glass replacement in round door mirror
    By obrut in forum Technical Info
    Last Post: 08-25-2011, 04:48 PM
  3. Pan replacement-FYI
    By tfmcmahon in forum Technical Info
    Last Post: 03-08-2006, 05:38 PM
  4. 65 911 alternator replacement
    By aracerx in forum General Info
    Last Post: 09-16-2004, 07:35 PM
  5. Oil tank replacement
    By 911kiwi in forum Technical Info
    Last Post: 07-01-2004, 05:22 AM
