Results 1 to 10 of 17
Thread: Break in for rebuilt engine
    Hello all,
    I just got my car home and I need advice on engine break in. I did a search and I'm surprised that I didn't find any posts.
    The engine is a 2.2 with Webers and a Solex cam that had a top end rebuild. It probably has a total of 100 miles on it now. How should I drive it for the first 1000 miles?
    Thanks in advance,
    Alan
    Mar 2006
    Louisville KY
    There is really two ways I have heard one is the slow and steady speed you know keep it under 55 and so on The other is drive it like you normally would I would ask the person who put it toghter
    I've heard both too. The manual says to keep the RPM below 5000 and avoid full throttle for the first 600 miles and then increase with some full throttle bursts up to 5500 RPM up to 1000 miles, then up to 6000 until 1200 miles. The shop that did my car is fantastic, but primarily a race shop so I thought I'd get the opinions of this very knowledgeable group.
    Alan
    One thing I'd suggest is dino oil at first, with more frequent oil changes than suggested....
    Drive it like you stole it ...
    Seriously, I say just drive it like you normally would. The motor will then "break in" to the way you drive.
    THEN drive it like you stole it.
    -Marco
    TLG Auto: Website
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    RGruppe #183
    Heat cycling the rings gets them seated. I've done pulls through 2nd, 3rd and 4th and then coast the bike down to cool it. I do this 4 or 5 times and I go home and dump the oil. I've never had a BMW (motorcycle) engine fail to seat the rings.
    Good luck,
    Tom
    Very interesting...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Quote Originally Posted by Alan B
    Since it was just the top end, and if the cams and rockers were not replaced, you really don't have anything to break in. So I would say drive it like normal.
    $.02
    Joe
    Now - 1993 C2
    Past - 1968 911L
    engine breakin
    I built a 2.2S specs with carbs. My mechanic had me keep it under 5k for first 500 miles then said drive it normal but not at a steady speed, i.e. speed up and back off as it helps rings to seat. He also had me drive it up a long hill (2-3 miles) at freeway speeds to heat and help seal the rings. Ran great after the 1st thousand miles.
    Michael
  1. Please info on Engine break-in with rebuild Webers
    By BartdeBruijn in forum Technical Info
    Last Post: 08-16-2012, 04:11 AM
  2. FS Rebuilt 1967 911 Engine
    By aturboman in forum For Sale: 911 Parts
    Last Post: 08-09-2011, 02:33 PM
  3. FS rebuilt alum 911 2.0 engine
    By rory gallagher in forum For Sale: 911 Parts
    Last Post: 12-09-2010, 10:17 AM
  4. 67S rebuilt Engine FS
    By dpegan in forum For Sale: 911 Parts
    Last Post: 04-20-2009, 08:02 PM
  5. Engine Rebuilt 2.2S
    Last Post: 05-14-2006, 04:59 PM
