Results 1 to 10 of 10
Thread: How to remove headlight assembly...
    Forgive me if this is really bad question, but how do you remove the headlight assembly?
    I only see one screw on the bottom and removed it. How much force is necessary to remove the unit? My fingers tips are about to fall off and I don't want to use a tool?
    Anyone have any suggestions??
    Thanks!!
    S Registry #835
    No help here, other than to say "NICE MARCHAL HEADLIGHT!"
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Vinny,
    There are NO bad questions...
    After you remove the screw, if you are trying to pry and pull your headlight ring straight forward to get it off ...... then it's doing it's job by not letting you. Give yourself, your fingers, and your old car a break and left UP and BACK towards the windshield... there is a little lip on the back edge of the top of the ring that holds it against a little boss that comes up from the top of the headlight opening.... to put it back on you just reverse the procedure and catch the top of the lip first, then line the screw hole up and replace the screw...
    Hope this helps,
    If "left up and back" doesn't work, you might try to lift up and back... (edit)..ditto on the nice headlight comment...now imagine those hiding behind a clear lens set up as being discussed on the general topics board....!
    OK, I will try that. Hopefully it works.
    PS I'm replacing these lights with the euro chrome h4 replacements so If any of you are interested in these PM me!
    S Registry #835
    I'm sure you'll find interested people if you advertise in "parts for sale" here.
    One final tip..when replacing that main screw? Note the angle it should be inserted, begin the screwing in with your fingers. It's too easy to strip the threads of the tab in the headlight bucket if you're not careful.
    it appears from the picture that the plastic inside ring is black was this painted?
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Quote Originally Posted by boxster03
    No it looks like black rubber material.
    S Registry #835
    interesting must be a yr/model difference as my original 1970 is kind of an off white plastic
    Lights
    Quote Originally Posted by VinnyC
    Sent you a PM
  1. Replies: 6
    Last Post: 02-18-2014, 05:10 AM
  2. WTB: New H-1 headlight assembly
    By Frank Beck in forum For Sale: 911 Parts
    Last Post: 03-18-2013, 08:55 AM
  3. Remove headlight switch
    By albuquerque in forum Technical Info
    Last Post: 11-12-2011, 03:29 PM
  4. WTB 1 Bosch H4 Headlight Assembly
    By aporschaguy in forum For Sale: 911 Parts
    Last Post: 05-07-2011, 09:48 AM
  5. NOS headlight carrier assembly
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 07-28-2010, 11:32 AM
