Thread: New speaker question
    How do I remove the dash speaker cover? I tried to carefully leaver it out with a piece of plastic but I stopped as I was afraid to scratch the dash. The previous owner had installed a modern cd system, but luckily the original radio came with the car. The modern speaker was placed in the foot well pocket and not the door pockets. I want to remove these modern speakers and hook up the original speaker. Buy the way there is no antenna on the front fender? Was the antenna always placed on the front fender? Maybe some previous owner has welded the antenna hole.
    1973 2.4S
    Dec 2002
    Birmingham, MI
    Fish something like a coat hanger through a hole and back out another hole several inches away. Then pull up on it. Or you could try to pull up at each corner. Wrap the end with tape. I can't remember if there is a way to get to the grille from the trunk compartment to push up... I don't think there is.
    Jared
    '73 911S #0793
    '69 912_ #0602
    Early S #0454
    RGruppe #0391
    I just placed a rag around the tip of a wide screwdriver & pryed up...the pegs holding the cover in are near the corners.
    Apr 2003
    Portland, OR
    Paul,
    Thanks! I have wanted to get behind my speaker grill to close the hole where the speaker used to be and was hesitant to just pry it out. Thanks for the details.
    2 minutes and voila! Problem solved.
    Harry
    Member #789
    2009 MB C300
  1. Replies: 5
    Last Post: 08-07-2013, 04:00 PM
  2. FS: 73 dash with speaker grill + 69 speaker grill minty
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 02-06-2013, 06:21 PM
  3. Unremovable dash speaker grill question
    By jazzyinco in forum Technical Info
    Last Post: 10-14-2012, 04:35 AM
  4. FS: 69-74 NOS Speaker
    By rick2 in forum For Sale: 911 Parts
    Last Post: 10-08-2006, 05:58 PM
