I want to install a harness bar in my '70 911. I will use it for 5 points and a camera mount.
The problem I have is that the mounting holes in the "B" post are approx. 2"-3" higher in a 1970 vs. 1972-73. Therefore a Weltmeister harness bar sits 2-3" higher than it should. The bar goes right across my line of vision. Also,the angle of the shoulder harness does not "feel" correct.
For those with a 1970, did you use a different mfr. or have a custom one made?
