Thread: Ethanol enhanced fuel question
    The SW portion of VA is going to a 10% enthanol blend of fuel in the next week or so. Does anyone have knowledge of possible effects on older 911's? I have a couple of cars with MFI, but I most concerned with a 3.0 CIS injected early car.
    Any thoughts on this?
    Bobby Smith
    Everything I've read is that 10% ethanol has no issues; we've had it in WA for years. It's the E85 that will most likely never run on MFI. I think the lubricity of fuel is the key to MFI pumps living a long life; ethanol doesn't offer much in that department.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    So, maybe add a little "Marvel Mystery Oil" to get the lube back???
    Apr 2003
    Portland, OR
    Orygun has been using EtOH fuels in the winter for years. Expect lower gas milage (5-10%) and think about an additive like Stabil to help keep the crud the EtOH attarcts in suspensiopna nd out of your tank. .
    Harry
    Member #789
    2009 MB C300
  1. E.P.A. Approves Use of More Ethanol in Gasoline
    Last Post: 02-06-2011, 04:46 PM
  2. Ethanol going to 15%?
    By NV Stig in forum Off Topic
    Last Post: 02-05-2011, 02:42 PM
  3. 10% ethanol blend update?
    By NV Stig in forum Technical Info
    Last Post: 05-21-2010, 03:24 AM
  4. 10% Ethanol questions
    By Bobby Smith in forum Technical Info
    Last Post: 06-26-2006, 12:10 PM
