Thread: 67 s numbers ?
    67 s numbers ?
    found this 67 on the internet
    305400 Vin
    909250 motor number
    97-6602-L in door jamb
    Is it an S ? and an S motor ?
    I tried looking in my 911 catalog but could not figure it out
    must be Monday morning....
    thanks for your help
    dave
    It is a 1967 Normal motor. Unless there is an 'S at the end of the VIN, it is a 1967 Normal chassis as well.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    S stamped in the car ?
    or S on the aluminum ID plate ?
    if its a 67 normal motor , probably a normal car....be sitting 20 years plus
    thanks
    I believe it would be stamped on both. All of the numbers are 1967.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    I think it's a build late 66, like the end of the fall.
    Richard
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    If it helps my car is chassis number 305457S with engine number 960138 which is an S with matching numbers and the car was built in August 1966.
    My Chassis number has the S on the VIN stamp on the car but not on the aluminium plate which I believe is not unusual. Can anyone confirm this?
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
  1. Comfort in the numbers
    By Chuck Miller in forum Technical Info
    Last Post: 01-07-2013, 04:33 AM
  2. Porsche Part Numbers to Bosch Part Numbers
    By FL-Frank in forum General Info
    Last Post: 06-28-2009, 08:56 PM
  3. Numbers numbers again...
    By BlutorangeS in forum Technical Info
    Last Post: 10-09-2008, 10:31 AM
  4. VIN numbers and dash rail numbers
    By davidppp in forum General Info
    Last Post: 08-21-2007, 09:01 AM
  5. Help with numbers
    By gilbert911 in forum General Info
    Last Post: 06-21-2007, 07:07 AM
