Thread: rev counter
    rev counter
    Hi
    How do I get the rev counter out of the dash? It is slightly turned clockwise with the redline at 12 o’clock and I wont it to be in the correct position. I tried to pull it out but it seems to be stuck.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Jun 2005
    Perth WA
    In my '71 the tacho is only held in by the rubber seal surrounding it, & so with some "gentle persuasion" can be pulled straight out, (or just rotated in situ).
    The 1st time I did it I do recall it toook a bit more grunt than I'd anticipated - but I maight have been a bit tentative in not wanting to damage it.
    Michael
    Michael
    If it won't budge try the speedo or temp/press on either side. Maybe you will have better luck if you can get a hand behind it. I had to work in series from the clock once.
    Dave Ebersole
    '78 SC
    Registry #873
    Thanks, that did it !
    (Removing speedo, hand behind)
  1. FS: 11/69 rev counter
    By moito in forum For Sale: 911 Parts
    Last Post: 03-10-2015, 01:34 PM
  2. FS: RSR / 914-6GT rev counter 10000u/min
    Last Post: 02-26-2015, 10:23 AM
  3. NOS 911 Rev-counter stamped 5.65
    By 67Porsche911S in forum For Sale: 911 Parts
    Last Post: 04-01-2012, 04:41 AM
  4. Post counter
    By davep in forum General Info
    Last Post: 02-23-2012, 06:26 PM
  5. FS: Clock and rev-counter
    By vricardo in forum For Sale: 911 Parts
    Last Post: 10-15-2007, 06:57 AM
