Thread: Rear Suspension Question
    I see in the PET that the rear suspension bananas are numbered differently between the 71 and 72....is there really a difference there of any note???? Would the 72 rear suspension fit right in the 71 without mods? I'm thinking of restoring the POS parts car suspension components for an upcoming project.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Dec 2004
    SE Michigan
    Don't remember, but I recall that there's some very good threads on Pelican that deal with this.
    Bill G.
    EarlyS #718 | RGruppe #437
    Rear trailing arms.
    Hello: You can put the rear trailing arms from any of the 911 long wheelbase cars onto that 71 car. The part number difference you are looking at maybe for a car with rear sway bar and without. The sway bar cars have a ball end welded to the trailing arm. Hope this helps. Thanks Eric
    Thanks Eric...my 72 parts car setup has the swaybar mounts along with the swaybars front and rear. I'm planning on using both. The goal is to restore my components to suit my needs first and then put them into a tub which I plan on seam welding and hanging a dumptruck full of 'glass on. Of course, like all good adventures of this nature, the plan will change as it evolves somewhat so I'm allowing for that but I needed to answer some of these basic questions first so I don't find out the hard way after...hehe.
    Paul Schooley
    S Reg #863
    R Gruppe #330
  1. 70S suspension restoration question
    By spankie in forum Technical Info
    Last Post: 04-13-2012, 05:40 PM
  2. Another SWB Front suspension question
    By MTemp in forum Technical Info
    Last Post: 07-25-2011, 08:52 AM
  3. Front suspension question
    By tar356 in forum Technical Info
    Last Post: 01-04-2010, 02:38 PM
  4. 71S suspension upgrade question-
    By 2008SPorsche in forum Technical Info
    Last Post: 04-27-2009, 05:39 PM
  5. Suspension Set-up Question
    By Paul W in forum Technical Info
    Last Post: 07-08-2006, 04:23 PM
