Thread: Fuel tank fittings
    Fuel tank fittings
    Just finished refurbishing the fuel tank in my 1968 911L. I have a question as to what the third fitting is in the bottom of the tank. Of the three, one is the supply to the pump with filter, there is one thats a drain, and a third that has a small outlet. Is this outlet an addition vent or a supply to something else. The cas smells like gas fumes sometimes up font and I am looking for the source.
    That is the fuel line for the Webasto heater. It should run from the outlet screen up into the smuggler's box.
    Thanks. I thought the car may of had a gas heater. Having never seen one I wasn't sure that was what the additional fuel pick up was for. If I don't have the heater so can I just block it off?
  1. MFI Injection Pump fuel line fittings
    By DerkBarrington in forum Technical Info
    Last Post: 12-28-2013, 09:44 AM
  2. Replies: 10
    Last Post: 09-12-2013, 01:53 PM
  3. Fuel tank fittings for 70T
    By erick72pors in forum Technical Info
    Last Post: 06-06-2013, 07:05 AM
  4. fuel accumulator/filter fittings plating ?
    By robmog in forum Technical Info
    Last Post: 01-19-2009, 11:37 AM
  5. Oil tank/cooler fittings question
    By gtgroupe3 in forum Technical Info
    Last Post: 07-24-2008, 09:24 PM
