Results 1 to 7 of 7
Thread: Swamp coolers
    Registered User
    Mar 2006
    Swamp coolers
    Did porsche ever use these? They are very popular with the early VW crowd out here in the desert.
    Attachment 19511
    Thoughts about using something like this on my 67?
    tadd
    B-b-buy Bushwood?!?!
    Feb 2003
    Topanga Canyon, CA
    How does it work?
    Sandy Isaac
    '69 911E
    #543
    I think I had one of those on a 53 Ford pickup.
    Rick
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Apr 2003
    Portland, OR
    Quote Originally Posted by SandyI
    How does it work?
    You dribble water over some packing and blow air over it at the same time, thewater evaporates and cools the air. Works very well in dry (<30% relative humdity) climates because it both cools and humidifies the air.
    http://www.wonderquest.com/swamp-coolers.htm
    Harry
    Member #789
    2009 MB C300
    Registered User
    Mar 2006
    Evaporative cooling
    Its a big tube with a venturi down the middle, as you drive water is pulled from the tank into the ventrui where it evaporates and cools the air. Evap coolers are very effective in low humidity enviroments. Our house has it (along with most in albuquerque) instead of AC.
    tadd
    Next time the weather is hot and dry, pull the trigger on a spray bottle aimed at your face. Very refreshing when the air temp is +90º (cheap A/C).
    Sherwood
    Registered User
    Mar 2006
    Hey...
    Then I could have way kewel eyeglass wipers!
    tadd
  1. Auxiliary Oil Coolers
    By sjuan in forum Technical Info
    Last Post: 10-17-2018, 04:11 PM
  2. Oil Coolers
    By jaudette3 in forum Technical Info
    Last Post: 02-23-2013, 06:35 AM
  3. New- 1973 only oil coolers - RS and S
    By Alan.uk in forum Technical Info
    Last Post: 12-18-2010, 08:26 PM
  4. 911 coolers
    By Original Poster in forum Technical Info
    Last Post: 10-14-2009, 07:28 PM
  5. 911 ST twin oil coolers
    By jan in forum Technical Info
    Last Post: 06-16-2007, 05:16 PM
