After much thought I have decided to sell my 70S. Originally I bought this as a companion to my '69 but it apparently got jealous and decided it wanted an engine reseal so money for the 70 has been depleted.
Let me start this off by saying this car is a basket case. While mostly complete and having what I believe are the original engine and tranny, it is completely disassembled for restoration and hasn't run in what I understand is about 20 years.
Good things:
1. Pans and suspension (torsion tube, front pan) are very solid. There is some rust in the dash corners (visible as dash pad is removed), the rockers appear to have been replaced as were the door jambs but more work is needed to complete. In the floor, there is a section in the passenger side footwell that needs minor work (CAR had AC and I think the AC leaked water plus the car sat) but the front pan, tank support and main pan are original. Jack mounts seem basically solid. Car needs a door skin on the driver's side, passenger is excellent.
2. has the hard to find S parts like the oil cooler system, MFI. Engine/trans are complete and not disassembled. Has glass and window frames.
3. Car is stripped down to a rolling shell saving someone a lot of time
4. I had the car sodablasted in and out but the car has an epoxy primer now to inhibit rust of bare metal. I have pictures to show someone of what it looked like pre-primer.
5. Clean NH title.
Bad Things:
1. Car has had the roof replaced but IMO it still needs work. The back window channel and sheet metal box section on the lower part of the rear channel show deformation from damage in the past. This will need to be cut out and replaced. I do not know if the car was rolled (necessitating the roof) or if something was dropped on it. Front windshield clearances also need to be checked out. I determined this after I bought it as PO expressed no knowledge on this subject. There was a previous post in which I discussed this with member feedback. I am sure this can be fixed at a nominal cost by someone with the right frame fixtures.
2. Car needs full paint and interior. I have seats but am not sure if they are the ones which came with the car originally. Original color was light yellow with a cork interior based on the color code and interior remnants.
3. Needs alloys (not with car). Rolling on steel wheels and bad tires.
4. Probably needs front hood and driver's fender.
This is a ground up project. I will probably list the car locally (here in CT) and on ebay so the question is what's a fair price. My goal is to sell the whole car and prefer not to have my wife all over me as I sell it off in parts and her car sits outside this winter. While I like to meet new people, I am interested in selling it and not just looking for the absolute highest price. But having seen some recent basket case sales recently, I think this car is certainly as good as some I have seen w/extensive rust or equally disassembled condition so I am looking for a "fair" view.
What are your opinions on the value of the car under these circumstances?
Jim L.
