Thread: Need Horn Part Number
    anyone have the part number for the contact pin that is made of plastic with the spring inside that fits under the horn pad that goes in the hole? Is it still available? thanks
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Horn Contact
    Part number 914.347.831.00 Stoddard has them for $25. Pelican shows them as NLA. I am sure other places have them. There is a guy on eBay that sells them with a kit that includes several other parts also for around $70. I assume this is the part you are talking about:
    http://www.stoddard.com/shop/shopexd.asp?id=2608
    Steven Shanofski
    1973.5 911T Sunroof Coupe - 414 Olive
    1970 911T Targa - Paint to Sample
    1955 Cessna C-170B (Gone but not forgotten.)
    I have a used one- appears to 'spring' just fine. If you pm your address I'll pop it in an envelope & mail to you.
    [Early 911 Registry #772]
    That is very kind of you. PM sent.
    Thanks again!
  1. Need help with part number
    By platas in forum General Info
    Last Post: 11-04-2013, 12:55 PM
  2. Part number help
    By classic in forum Technical Info
    Last Post: 04-19-2012, 06:33 PM
  3. Air box part number, what do I have?
    By tomt in forum Technical Info
    Last Post: 12-10-2011, 12:35 PM
  4. Help with part number 901.501.898.0
    By WM711 in forum General Info
    Last Post: 02-07-2007, 10:35 AM
  5. help ID this part number
    By typ901 in forum Technical Info
    Last Post: 01-18-2007, 12:40 PM
