Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Pertronix Ignition Problem?
  1. #11
    Here is a thought...check the battery to see if it is fully charged and getting a charge. Since all of the items that you mention are effected by voltage. Ground even? This may not help but you have to know what is right to find out what is wrong.
    Rick
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
  2. #12
    Not tempeture related drove just as bad cold as hot. I used the Eastwood kit on the fuel tank so the tank and lines are like new. Will try a different battery. Could explain wht it ran good and then bad. Ordered coil and points to install next.
  3. #13
    Tank coating
    Hello: I had a customer car that had a coated tank and the coating was peeling away and plugging the vent hole and the pick up on the bottom. I also have a customer who had water in the tank problems. It was from a bad fuel cap. When he washed the car it would allow some water to get into the tank and then it would run bad. New cap was installed problem solved. These are just weird things that I have seen. Good luck and let us know what you find out. Thanks Eric
  4. #14
    Quote Originally Posted by Steve@Rennsport
    FWIW,..I've had nothing but HUGE grief from Facet fuel pumps in each and every case and replacement would be at the top of my list here,....
    IMHO, they are simply a curse.
    Facets have been junk for years. At least 20-25 if my memory is treating me fairly tonight.
    Tom
  5. #15
    Facet fuel pump
    Hello: As a side note the Facet pumps work ok on lawn tractors and for removing fuel from motorcycle gas tanks. They to seem to work on 912's as well. Thanks Eric
  1. Replies: 0
    Last Post: 11-15-2010, 07:53 AM
  2. S ignition kit : NEW Pertronix, Cap and rotor
    By RS-GT in forum For Sale: 911 Parts
    Last Post: 02-16-2010, 05:47 PM
  3. FS: New Pertronix ignition for 73+
    Last Post: 10-19-2009, 06:29 PM
  4. Installing Pertronix Electronic Ignition
    By shipard in forum Technical Info
    Last Post: 08-31-2008, 05:22 AM
  5. Ignition problem
    By DGood in forum Technical Info
    Last Post: 10-25-2003, 10:38 AM
