Thread: Cylinder Head part numbers
    Mar 2006
    Louisville KY
    I have a set of heads I would like to know what kind of car they are from I believe they are "E" heads off of a 69 not sure though #901-104-306-2R
    I want to sell them but want to know what they are for sure
    Hi:
    The most accurate way to determine what heads you have is to measure the intake port size and post a picture of the combustion chamber side of the heads.
    Casting numbers are notoriously misleading,...
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    If you'd taken all of 2 seconds to search, you'd have found your answers in this thread:
    http://www.early911sregistry.org/for...t=head+numbers
    If they have MFI ports, they are almost assuredly the 'E' heads, as they have the same port and valve specs as the 'T' heads.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Mar 2006
    Louisville KY
    Sorry about that one I saw that post again I remembed seeing that info some where but couldn't remember where Thanks for the info
    No worries!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    cylinder head id help!
    hi everyone,
    would anyone happen to know what year and type car the head on a motor i just purchased is from?
    the numbers stamped on it are: 930 104 329 2R
    thanks!
  1. Head part numbers
    By Christian Guthrie in forum Technical Info
    Last Post: 03-19-2013, 07:04 AM
  2. 1973 S Cylinder head part numbers?
    By joseph battista in forum For Sale: 911 Parts
    Last Post: 12-06-2011, 01:08 AM
  3. Porsche Part Numbers to Bosch Part Numbers
    By FL-Frank in forum General Info
    Last Post: 06-28-2009, 08:56 PM
  4. question about part # for cylinder head
    By teescott in forum Technical Info
    Last Post: 02-28-2006, 05:54 PM
  5. Cylinder Head Part Number?
    By gruen911 in forum Technical Info
    Last Post: 07-22-2005, 04:26 AM
