Results 1 to 2 of 2
Thread: How to connect an oil line?
    Mar 2005
    I am putting in an cam oil line as part of updating the chain tensioners on my 69S. The oil line came with no connector on one end. I purchased a nut and a ferule (?). How do I attach the hardware to the oil line, do I use a special tool that expands the end of the oil line, use glue or what?
    Don
    1963 356B Super
    1969 911S
    1981 911S
    Since you have a ferrule, this implies that you have one component of a compression fitting. The ferrule slips over the tube and is captured between the nut and the mating fitting that the nut screws on to. When the nut is tightened the ferrule swages the tube making a leak tight seal. No sealer is used in this type of fitting, but a little oil on the threads will be beneficial. Do not over tighten! About 1 - 1.5T from lightly seated should be fine.
    Leaf green 72T, SOLD!
    Gone back to my MoPar roots!
  1. Help needed : how to connect a 10000rpm tachometer
    By jdj123 in forum Technical Info
    Last Post: 02-27-2014, 07:09 AM
  2. Should the air intake hose for 1972 911T connect to anything?
    By SpawnyWhippet in forum Technical Info
    Last Post: 12-31-2013, 08:03 PM
  3. R Gruppe re connect help
    By geneulm in forum General Info
    Last Post: 01-16-2012, 05:56 PM
  4. Replies: 3
    Last Post: 05-09-2011, 08:14 PM
  5. Which battery to connect for a jump start?
    By nickR in forum Technical Info
    Last Post: 01-20-2007, 10:09 AM
