Results 1 to 10 of 18
Thread: Jack plug for 73 and earlier?
    I needed a couple of new jack plugs for my 73.5 911 and placed an order without looking too hard at the specifics. They came in but are too short to be inserted in the hole. I then looked at my order and noticed that it said for years 74 - 89 or so. I then looked some more to order the correct part, including speaking to a Porsche dealer and had no luck.
    What solution have you guys found?
    Thx,
    Ashford
    Jan 2003
    UK
    Pre-'74 911's did not use a jack hole plug.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    plug it with por 15
    Mike
    S Registry #825
    73.5 Dalmatian Blue
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    If you don't plug it now with the POR 15 you will later
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Fill it with lead then cover with bondo.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hehehe....lethal injections of por15 and everything is right with the world!
    Paul Schooley
    S Reg #863
    R Gruppe #330
    OK then, I'm at a bit of a loss, so please tell me what I'm looking at.
    Thx,
    Jul 2003
    Santa Cruz, CA
    If your car is truly 73.5 then someone has added later rocker trim.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    That is a G body/ 74-89 rocker which was the only jack point that used a plug. The dealer should carry it.
    Don
    Oct 2005
    wash dc/ los angeles ca
    Wink Jack plug ?
    Right Don,but the "G" body rocker cover and moulding installed on a "F" series
    car prevents the correct fitment of said cover because its length wont allow
    it to go into the jack tube which is what actually holds the plug ..Bert
  1. FS: 911/912 Hood (73 & Earlier)
    By byron in forum For Sale: 911 Parts
    Last Post: 11-13-2013, 03:38 PM
  2. 68 and earlier tool kit
    By bmendel in forum For Sale: 911 Parts
    Last Post: 07-13-2009, 07:28 PM
  3. 73 or earlier sunvisors for sale
    By BOYER73S in forum For Sale: 911 Parts
    Last Post: 07-07-2009, 02:17 AM
  4. 67 and earlier SWB parts needed
    By Ralfy in forum For Sale: 911 Parts
    Last Post: 06-26-2009, 09:29 PM
  5. Interesting accessory: jack spur plug
    By NTW in forum General Info
    Last Post: 07-24-2008, 09:29 AM
