Thread: Loctite 574 didn't work what now?
    Mar 2005
    A couple of the studs which hold on the chainbox cover will not tighten enough to allow me to tighten the nuts. I tried Loctite 574 but it didn't work. Is there something else that might work or do I need to buy new studs?
    Don
    1963 356B Super
    1969 911S
    1981 911SC
    Don:
    # 574 is a sealing compound used specifically on flat surfaces,...
    If the studs are rotating enough to prevent the nuts from snugging up, then deal with that by either repairing the stripped/damaged threads or in a pinch, anchoring them with Locktite # 270 which is a high-strength stud & bearing mount. The threaded hole and stud MUST be scrupulously clean.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    You must have the studs fully seated as I suspect you are trying to tighten on the unthreaded portion. There are tools for installing studs but utilizing 2 nuts by jamming one against the other works too.
    http://buy1.snapon.com/catalog/item....re&dir=catalog
    Loctite should "nail" them in IF you don't have stripped threads in the case itself. That's another ball game.
    http://www.loctite.com/int_henkel/lo...d=363&layout=1
    There is a nice chart that lists applications.
    262 or 272 look to be the product.
    Good luck,
    Tom
    Stripped stud holes?
    Hello: I'm a little unsure of your problem. Are the holes that the studs go into stripped? If so you will have to Time sert them to restore the threads. You can also get oversize studs on one end from Volkswagon. They are 7mm and 6mm on the other end. If the threads are bad on the studs then just replace them. Hope this helps. Thanks Eric
  1. Anyone have the knowledge on Loctite?
    By obrut in forum Australia
    Last Post: 03-02-2012, 02:50 AM
  2. Work on GT Seats
    By John Straub in forum General Info
    Last Post: 03-04-2008, 04:05 PM
  3. A work of art...
    Last Post: 11-21-2006, 05:03 PM
  4. '67 S - Needs work
    By 72targa in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 03-12-2006, 08:34 PM
