Results 1 to 1 of 1
Thread: 73 914 3.2l
    73 914 3.2l
    Arctic blue Porsche 914 built by Fordahl Motorsports in 2003. $40,000
    Car has the following installed: '85 3.2L w/ Euro DME, '89 911 hubs and discs, '03 Boxster brake calipers, 9.0x17 Fikse FM10 wheels, Yokohama A032R-S tires, OMP GRIP Kevlar race seats. Details...
    Body
    M474 fender flares in composite.
    fully welded chassis stiffening kit
    flared rocker panels to match fenders.
    front valence modified for oil cooler.
    rear valence modified for dual exhaust.
    Chassis, front:
    '89 911 hubs, vented rotors, bearings
    22mm front hollow torsion bars
    Poly Graphite suspension busings
    JRZ 12-way adjustable front struts
    Monoball upper strut mounts w/ camber plates
    TRG 24mm adj. front swaybar
    12mm steering rack spacers
    Chassis, rear:
    boxed rear control arms
    225lb rear springs
    JRZ 12-way rear dampers on invert mounted custom hardware
    modified stock rear swaybar
    Engine
    '85 Carrera 3.2
    new bearings, seals, rings, valves, valve guides, return tubes, valve grind, cams, fuel pressure regulator, cyl. head temp. sensor
    custom lightened flywheel
    delete A/C pulley
    front mount 914/6 style 60 row auxiliary oil cooler
    3.2 oil cooler on engine
    Euro DME w/ performance chip (91 octane)
    K&N cone filter on adapter
    MSDS 1 5/8 headers, cermachrome coated
    FM/Flowmaster custom muffler, titanium coated
    troutman oil cooler thermostat 180deg.
    Transmission
    901 gearbox
    Quaife torsen LSD
    new bearings, synchros, sliders
    billet bearign plate
    Swepco 201 gear oil
    Unsprung weight
    Fikse FM10 forged modular 3pc wheels (9.0x17)
    245/50ZR17 Yokohama A032R-S
    2003 Boxster monoblock calipers front and rear
    Porterfield R4 race pads
    SS brake lines
    19mm brake master cylinder
    Interior
    M&R camlock racing harnesses (5 point)
    new MOMO suede steering wheel
    email "paulhag1@hotmail.com" for more information. Car is located in Seattle, WA area
