Results 1 to 2 of 2
Thread: Door Weatherstripping
    Does this weatherstrip (with the vertical ribs) look like the stock weatherstrip for a 1973T?
    I cannot get my door to adjust flush and still have the latch operate easily, and I'm wondering if aftermarket weatherstripping was used by a PO (maybe it was too thick).
    Any ideas?
    Thanks.
    Of course check in the channel for consistant depth. There were 3 pieces of bodywork that stacked right there where you show out of 4 overall. Have your rockers/ longitudinals been replaced? Some don't get that just right. What you can do is remove some of the rubber off the back of the w/s if you can't get the clearance you need in the channel. Or, you can stretch it a little thinner there when you glue it in. HTH.
  1. FS: 68 door shells no rust, 67 pass door panel/arm rest, fuch rims
    By scwhite59 in forum For Sale: 911 Parts
    Last Post: 08-14-2013, 04:31 PM
  2. Replies: 7
    Last Post: 03-19-2011, 07:11 PM
  3. Replacing outside window weatherstripping
    By Dmill in forum Technical Info
    Last Post: 05-23-2007, 08:24 PM
  4. Supplier for a weatherstripping kit
    By Nick in forum General Info
    Last Post: 12-16-2006, 06:56 PM
  5. opinions on rubber/weatherstripping?
    By jkolesa in forum Technical Info
    Last Post: 02-28-2001, 10:16 AM
