Thread: Oil Leak
    Mar 2006
    Louisville KY
    Oil Leak
    I have a early 911 with the center lube cams and I have an oil leak on the left side of the motor it puddles up under the solex fuel pump base gasket I have replaced the gasket twice the oil line is not leaking I was thinking that mabe the collective minds of the forum might be of some help.
    Thanks Tony
    Do you have a phenolic spacer between the fuel pump and the case? If so is it cracked? I don't know the Solex 911 at all, so I really don't have a visual of your problem area. I would say clean the area thoroughly and inspect carefully while the engine is running - you gotta catch this stuff in the act.
    Leaf green 72T, SOLD!
    Gone back to my MoPar roots!
    Mar 2006
    Louisville KY
    It has webers now so I have tried it both ways with the spacer and also just with a gasket
  1. Gas leak.
    By r14 in forum Technical Info
    Last Post: 09-26-2012, 10:45 AM
  2. Need help with gas leak in my 73S.
    By merbesfield in forum Technical Info
    Last Post: 05-24-2011, 06:09 PM
  3. Oil leak
    Last Post: 12-02-2006, 02:21 PM
  4. Oil Leak 2.2
    By Type911 in forum Technical Info
    Last Post: 09-18-2006, 07:47 PM
  5. Oil leak on 69S
    Last Post: 01-24-2006, 05:52 AM
