Hello just have a easy question. How do you get the Cigaret lighter housing out of the dash? Wires are all off and the lighter itself is removed. Still can't see how to losen the housing and get it out. Thanx in advance.
Regards Bill
Regards Bill
Bill Barnich
R Gruppe Nr.230
Early S Nr.960
71 911T/2.7 Tangarine
73 911?/3.6 work in progress
the cig lighter is two pieces and has to be unscrewed from behind the dash.
'67 911S
'69 911S
'70 911ST
'73 911T Targa Signal Yellow
'11 Spyder
Early S#1097, R-gruppe #
Just to clarify endo's post. The entire outer backshell of the lighter viewed from the trunk needs to be unscrewed. It's hollow and threaded. This effectively clamps the front bezel portion of the lighter against the dash. Once unscrewed completely, the main housing pulls out from the front of the dash.
You shouldn't need pliers or tools. Just reach up there and give it a good turn lefty loosey.
Michael
-Dusty 70S Coupe
-S Registry #586
This took me months to finally figure out.
It was basically the last thing in my shell before media blasting. It was really tight so I just assumed there was a trick I hadn't figured out yet.
1970 911S Targa
On the road again soon.
Thanx. I knew it was something simple, just a little too simple! Thats where I'am at now Bob. The wiring behind the dash was very imtimidating. Reminds of the british cars that I swore off. Amazing how such a well desigined car could have a nest like that. This going to be fun. Thanx all
Bill
Bill Barnich
R Gruppe Nr.230
Early S Nr.960
I agree.
The wiring behind the dash is a mess. But, on the otherhand in the engine compartment it is quite tidy. Electircal is not my strongest skill so I am making sure I test all components and wire harnesses on the bench before I reassemble my car. Tested the horns and MFI cold start components this week....
1970 911S Targa
Hey Bob electrical is not my strong point either, then add being colar blind to boot. It will take a couple of friends a few beers and who knows how many evenings but it will get rewired. They have pitty on my handicap but understand. What type of meida blasting did you have done? And did you have to remove all the rust proofing before hand? What was the easist way of removing it? Thanx.
Bill
Bill Barnich
R Gruppe Nr.230
Early S Nr.960
I used walnut blasting to remove all paint and underseal then garnet to remove any localized corrosion.
Walnut removed the underseal because it is so old and hard otherwise it should be removed using other techniques. Wurth makes a wire wheel tool that removes it very well.
I have paid a total of ~$1500 to have every panel and chassis done. Money well spent given the nature of the work. Terrible messy and hard on the body if you choose to do it yourself.
1970 911S Targa
