Results 1 to 9 of 9
Thread: Original Battery Ground Strap?
    I am wondering if this the original ground strap for the batteries of a 1970. I have one like this and then another that I suspect is not original.
    I would like to find a match to this if it is correct and if it is not correct a pair of the original ones.
    Thanks in advance.
    Bob
    1970 911S Targa
    On the road again soon.
    No, that is a later strap like the one I had in my 964.
    Original will be flat, the LWB is longer than the SWB, copper, with tinned ends.
    LIke this one. They're easy to find from the usual sources.
    I know you're after total originality, but a good trick before you put new ones on is to hold both ends in a "U" and dunk the braided part in a can of black Plasti-Dip. It puts a nice rubbery coating on which keeps them from scratching anything or coming apart as easy as they tend to do where they have to twist when mounted.
    John Gray
    70 old air
    86 middle air
    95 new air
    Thanks guys,
    I thought those were generic Pep Boy specials that Pelican was selling. I have one as you show and the one in my pic.
    Bob
    1970 911S Targa
    I have two, a 71 and a 72; and all are flat for the grounds like GreenT is showing.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Aug 2005
    Rancho Cucamonga
    The Cable Twins.....
    I think you need these 2 little guys
    901.611.902.21
    Attachment 21773
    Bobby,
    All my 73 and earlier cars have had the flat style as pictured.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Thanks Guys!
    The part number has been added to my list of things to purchase.
    1970 911S Targa
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    there 25 dollar i belive!
  1. 73 S - engine lid ground strap?
    By mac73s in forum Technical Info
    Last Post: 07-28-2013, 01:47 PM
  2. Replies: 9
    Last Post: 03-24-2013, 12:48 PM
  3. Battery Ground Strap
    By boxster03 in forum Technical Info
    Last Post: 02-21-2010, 08:23 AM
  4. FS Wingnuts...Really! Ground strap
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 05-23-2007, 08:18 PM
  5. Is 69 tranny ground strap different?
    Last Post: 05-11-2007, 04:49 PM
