Thread: Small Rubber Pan Plugs
    Oct 2004
    SW Suburbs of Chicago
    Sorry, camera is here and the car is there; these are the rubber plugs, about 8 or 10 in all, that fill the small drain holes under the tunnel (looking at the pan from below, they run front to back in the middle of the pan) and there are two of them in the front pan. Even the parts book doesn't show them. Stoddard lists plastic plugs, but these have a hole in the middle like drain plugs and they are rubber. Any ideas where to get them?
    Oct 2004
    Got an answer on Pelican, they are part # 111.801.177, available from Pelican parts as "door plug". Part book calls for only 4 of them, but I think there are more than that Hmm...
    Oct 2004
    Wow, I answer myself twice. Stoddard does have them. Their search engine is a little deceptive. I searched under 911, 914, 356 and couldn't get a hit, then tried the number without any model number and got a hit. Anyway, there they are, 111.801.177.
    Thanks for answering yourself I will order some now also
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
  1. Rubber seals and other small items for sale
    By Ruby911 in forum For Sale: 911 Parts
    Last Post: 03-25-2011, 05:52 PM
  2. Rubber Body Plugs Available?
    By garycox in forum General Info
    Last Post: 04-23-2010, 04:48 AM
  3. Source for original style rubber door plugs?
    By Grun68 in forum Technical Info
    Last Post: 02-05-2009, 05:35 PM
  4. more on rubber plugs-search
    By TRE Cup in forum Technical Info
    Last Post: 10-04-2003, 07:40 AM
  5. Rubber door plugs
    By fryardds in forum Technical Info
    Last Post: 09-30-2003, 08:44 AM
