Thread: Window regulator spring pin, available?
    Anyone know if the pivot pin for the window regulator spring is available anywhere? This is the aluminum pin that is peened into one of the window regulator arms and hinges 2 others finally holding onto the center of the regualtor spring. This one is from my 1971 911S. I could lathe one out, but rather buy one if available. Thanks Allan
    1974 914 2.0 Yellow/Black
    Pelican, Tweeks, probably Stoddards.
    Given all the metal work you have done you may as well make your own.
    Took me about 30minutes....
    1970 911S Targa
    On the road again soon.
    Apr 2003
    Portland, OR
    You can find them listed at Performance Parts here: http://www.automotion.com/productpag...egulator+Pivot
    I replaced mine recently. took about 4 hours for the first door and 2 hours for the second. There are 4 "flavors" of the pin. It looks like you have the parallel style. Get a length to be sure you order the correct type.
    Harry
    Member #789
    2009 MB C300
    Thanks guys, knew I came to the right place, finally found it on the Stoddard site for 18 bucks. Could make one, already have the aluminum, but for 18 bucks and 18 project cars, I'm racing to get them all done before I die lol, thanks again Allan
  1. Window regulator
    By mike curnow in forum Technical Info
    Last Post: 11-14-2023, 06:22 AM
  2. WTB: Hirschmann aerial & window regulator spring
    By murph2309 in forum For Sale: 911 Parts
    Last Post: 02-05-2014, 07:57 AM
  3. FS: Window Regulator Motor
    By greenrubbermatt in forum For Sale: 911 Parts
    Last Post: 02-03-2014, 03:55 PM
  4. WTB: Window regulator spring
    Last Post: 01-01-2014, 02:53 AM
  5. Window Regulator Spring
    By bobmagyar in forum Technical Info
    Last Post: 01-04-2006, 02:27 PM
