Results 1 to 8 of 8
Thread: help with sport seats
    Apr 2004
    35,000 ft
    I finally scored what I think is a nice set of sport seats for my '69 911 S, they are vinyl, single lockers, need a bit of work, but have the right amount of patina to match the car.
    I'm trying to figure out how to mount seat belts to the seat. One side is drilled, so it will accept the standard seat belt mounting hardware, but the other side will need some modification. Also, one track is a tilt base, the other is not, was this common?
    Any thoughts??
    Attachment 22156
    Attachment 22157
    Attachment 22158
    Apr 2003
    Quebec, Canada
    Seat belts
    Hello
    I think this is what you need for the seat belts, like RPMclassic offer to you on pelican board ,one each side for the belt end and one for the receiver.
    and for the track,I saw a set like your on ebay Item number: 300011405114
    but expensive ...
    I hope you can result the problem and use your seats in your 911.
    Raynald
    1973 RS Réplique
    http://pages.globetrotter.net/rayfec/
    Apr 2004
    35,000 ft
    I have a set of these brackets, on my stock seats, that I plan to transfer over, but the seat sliders do not appear to have mounting points for these on both sides, only on the outboard side of each slider, so I need to figure out where and how to mount the belt receiver.
    thanks
    -Lewis
    Apr 2003
    Quebec, Canada
    Receiver
    Hello M. Lewis
    can you check the pictures of this post :
    http://forums.pelicanparts.com/showt...elts+receivers
    Ray
    1973 RS Réplique
    Apr 2004
    35,000 ft
    Raynald,
    I have the brackets and receivers and they are correct, what I'm trying to find out is how they should mount to the sliders that I have, since the sliders have holes on the outboard side only, I was hoping someone would recognize these sliders and have an easy solution.
    thanks
    -Lewis
    Apr 2003
    Quebec, Canada
    Hello
    I think You have to install the L brace between the track and the floors car,
    I have to go for one week of working out of town !
    Raynald
    1973 RS Réplique
    Seattle WA
    Those aren't the correct sport seat tip brackets.... Original sport seat bottom brackets/sliders are pictured below, and have attachment points for the seat belt receptacles "built into" the bracket.
    regards,
    Eric
    Apr 2004
    35,000 ft
    thank you.
    I've removed my non-sport seats and removed the seat belt brackets and they will not mount up to anything. They don't mount to the sliders and the holes are not quite right to mount to the location where the original seats mounted to, seems I was misled by the seller. These don't look anything like the sliders I have seen elsewhere.
    -Lewis
  1. Replies: 1
    Last Post: 07-13-2014, 05:50 AM
  2. Recaro Sport S seats .... Scheel 400 Rallye Seats/tilt slides
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 08-06-2012, 02:42 PM
  3. WTT: Late Sport Seats For Early Sport Seats
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 01-06-2008, 12:15 PM
  4. WTT: Late Sport Seats For Early Sport Seats
    Last Post: 07-31-2007, 10:14 PM
  5. Replies: 1
    Last Post: 09-28-2006, 10:17 PM
