Thread: Brake line source
    Brake line source
    Does any one have a source for the steel brake lines on a 1968 911? I am going to up grade to Stainless flex lines and would like to change all the steel lines at the same time. I don't trust almost 40 year old steel lines.
    Mar 2006
    Louisville KY
    I would think any good autoparts store would have brake line you will need european fittings there is a difference in japense and euro.
    The hard brake lines should be available from Stoddard or your dealer. As an alternative, Inline Tube (586-532-1338) will make the lines for you in either regular or stainless steel. You send them your old lines and they copy them.
    Good luck, John
    Early S Registry #630
    71 911S Irish Green
    65 911 #301826, Silver
    57 Speedster #83702 Aquamarine Blue
    Yes, Stoddard offers seprate lines or line sets. The trouble is that they need to be bent to shape.
    Are the lines from Inline tubeing bent to order? I have tried twice to get a brake line bent now on my own, with a bending tool. It works but dose not look factory. The tie rod pinched mine when the strut was pulled off the ball joint end in my mishap in May.
    Regards, Bill
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
    Inline Tube (and I'm sure there are others) will laser scan your old lines and make exact duplicates using computer CNC benders.
    http://www.inlinetube.com/
    Best, John
    71 911S Irish Green
  1. SS brake line
    By Bob Harriman in forum Technical Info
    Last Post: 08-03-2012, 05:33 PM
  2. -2 instead of -3 brake line
    By 912-2.8 in forum Technical Info
    Last Post: 04-19-2011, 06:48 PM
  3. Source for cloth braid oil breather line?
    By Cornpanzer in forum Technical Info
    Last Post: 08-29-2008, 01:00 PM
  4. Source for Brake line, S Caliper?
    By caproader in forum Technical Info
    Last Post: 09-27-2004, 05:31 AM
  5. Oil line metric to AN fittings source
    By bluefin9 in forum Technical Info
    Last Post: 12-21-2002, 04:27 PM
