Results 1 to 10 of 10
Thread: Best strut brace?
    Mar 2005
    Best strut brace?
    Anybody got an opinion on who makes the best strut brace? Are these hard to install? Are they worth the money? Is a three point brace worth the extra money compared to the two point brace? Are there other low cost modifications I can make to my front suspension that will improve cornering? Thanks.
    Don
    1969 911S
    1981 911 SC
    Dec 2004
    How do you intend to drive the car?
    Are you going to race/autocross or just fun on back country roads?
    Strut bars do make a difference when the car is placed under stress, but it takes a lot more than just average fun to flex the body to the point where a strut bar has any effect.
    IMO---in many cases, a strut bar is money wasted.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Suffolk, VA
    A strut bar will help in racing or autocross, but probably not under normal street driving conditions. The two point brace gives you a structural quadrilateral, not good. With tube frame structure, you need triangles. So the three point is better.
    Citation F1000 on the way
    Other Early 911/912/914
    Here is the strut brace we make, it makes a noticeable difference in most situations and speeds, even entering a drive way. I believe someone in the US was making a similar unit in the early 90's, don't know if they are still available. One comment we have had is it makes a Targa feel like a Coupe.
    Mar 2005
    Pulling into the driveway? Sometimes when I hit a bump in the road the front will shudder for a second or two. Will it fix this?
    Don, your problem will not be related to chassis flex, rather an issue with one or more worn component, such as a ball joint, or a tie-rod end. Start by checking those first. How are your shockers and bushes?
    Mar 2005
    I had new shocks/struts (Boge) all the way around. I had new turbo tie rods and ends put on about a year ago. Maybe I should try new A-arm bushings.
    Senior Member 72tii's Avatar
    Nov 2004
    Bedford, TX
    Cambermeister on '68 911
    Does anyone know why the Weltmeister Cambermeister strut brace won't work on a '68 911? It shows to fit '69 through '89 cars, but PET shows the upper mount with part number 901.341.018.01 to be the same for '68 and '69.
    I tried e-mailing Weltmeister, but haven't heard back from them.
    Mike
    1968 911 #11830241
    Early S Registry #810
    R Gruppe #461
    Triangulation is the way to go. Check out the Elephant Racing brace as well.
    A.T.
    Early 911S Registry Member #500
    Mar 2005
    I am going to replace the Boge shocks with Koni. If it does not work, I will try something else.
    Don
  1. RSR Strut Brace
    By B D in forum Technical Info
    Last Post: 06-04-2007, 06:56 PM
  2. WTB - Strut Brace
    By 72911E in forum For Sale: 911 Parts
    Last Post: 05-23-2007, 09:02 PM
  3. WTB Used Strut Brace
    By ljowdy in forum For Sale: 911 Parts
    Last Post: 02-15-2007, 07:25 PM
  4. strut brace
    By xlboy in forum Technical Info
    Last Post: 05-07-2006, 05:17 AM
