Thread: 73.5T cold start
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    73.5T cold start
    My CSI 73 cold start valve does not have 12 volts going to it when cold , the wire diagrams are not helpful ! does anyone know what triggers this? Thanks . 1973.5 T Sambesi Green !
    Ignition switch on and 12 volts!
    All kidding aside, you must check your relays and wiring. ALWAYS use you hand throttle when starting one of these cars. Always.
    There are BIG wiring diagrams somewhere that are really easy to read. Get you hands on one and I think life will get better for you.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    Jul 2006
    Pine Bush NY
    does it put out the 12 volts to the cold start valve only when cranking?
    Apr 2003
    Portland, OR
    gumby,
    The Pelican Parts Web site (http://www.pelicanparts.com/index.htm) has the the wiring diagram you need to understand how this works. Just hit the link on the side labelled "Elec. Diagrams".
    The cold start injector will only activate when you crank the car and you have the hand throttle lifted up.
    Harry
    Member #789
    2009 MB C300
  1. 73.5 CIS cold start
    By Mac911 in forum Technical Info
    Last Post: 04-23-2024, 12:57 PM
  2. hard cold start
    By robmog in forum Technical Info
    Last Post: 05-07-2012, 06:12 PM
  3. cold start solenoid
    By cmcfaul in forum Technical Info
    Last Post: 04-24-2011, 05:12 AM
  4. cold start problem 71T
    By super9064 in forum Technical Info
    Last Post: 06-04-2007, 08:57 AM
  5. MFI cold start proceedure w/ cold start disabled
    By Type911 in forum Technical Info
    Last Post: 09-22-2005, 11:41 AM
