Thread: Cleaning/polishing the muffler
    The muffler on my car has a lot of brown stains/discoloration (not rust), and I'd like to clean it up. I think it's a stainless steel unit installed when the car was new.
    Will regular engine cleaner do the job? Mother's mag and aluminum polish? Maybe just some vinegar?
    You'll have to take it off the car to do it any justice in cleaning it.
    I've polished one in the past. Never more!
    Any good metal polish will work but I would suggest that you use some sort of air/electric contrivance (buffer) to aid you. Otherwise, you'll be rubbing until you're blue in the face.
    Once done you can count on doing it again and again. S/S turns yellowish-brown with heat. Nothing will stop it unless you decide to have the system coated (Jet Hot, etc.).
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    As Tom said you should remove the muffler to really do a thorough job.
    I have a full stainless muffler on my SC , Mother's polish works very well to bring back the shine & remove the yellowing from heat.
    Don't tell your friends & family you spent half a morning polishing your muffler
    1973 911E Viper Green
    2021 Spyder PTS Signal Yellow
    2019 Carrera T Racing Yellow
    2008 Boxster S Ltd. Ed Orange
    2007 911 GT3 Meteor Grey
    @Type911 instagram
    RGruppe #295
    Zuffenhausen secret weapon
  1. Polishing scratches out of windshields?
    By Shaun 69 E in forum Technical Info
    Last Post: 01-06-2010, 09:21 AM
  2. Polishing Plexiglass
    By hdavis in forum General Info
    Last Post: 11-18-2006, 09:21 PM
  3. Polishing Clear Coat
    Last Post: 09-05-2006, 07:00 PM
  4. Polishing stainless steel
    By darkbeer in forum Technical Info
    Last Post: 01-04-2005, 08:39 PM
  5. Windshield Polishing?
    By SandyI in forum Technical Info
    Last Post: 05-22-2003, 07:04 PM
