Thread: steering wheel question
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    I just installed a Momo Prototipo in my 73S (boy was that center nut a bugger to loosen). I like the thicker diameter and smaller wheel but I'm not sure I like the distance that the 0230 hub adapter places the wheel from the turn signal and wiper stalks. It's a bit too far from the dashboard. Also, the right side turn signal cancel feature quit on me?! 1) Are there other hub adapter sizes available, and 2) Is the new wheel the cause of my turn signal not clicking back or is my car pissed at me for replacing my 380mm perfectly fine steering wheel? Thanks.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Nick,
    1. I have had 2 different Momo hubs in my car. The first is the commonly available collapseable ribbed version you describe nad the second being the hard to find bell shaped version. The bell shaped version is shorter and people will often run a spacer combo to give it height. I am currently running the bell shaped version with a flat prototipo which is a great combo. I will soon be doing the opposite of you as I wait the return of my 380mm from Tony.
    2. You might want to check the steering column for the "fingers" which I believe are on the left hand side. They sometimes get bent and will no longer engage the cancel ring on your hub.I have had to "fine Tune" mine in the past by bending them back into place.
    Question: for people running the original 400mm wheel, what is the distance from the wheel to the dashboard. With your hand in the 12 o'clock position, do your fingers touch the dashboard when extended and your hand still on the wheel?
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Senior Member hgarazo's Avatar
    Jan 2004
    Frederick, MD
    Bob,
    Could you comment on your findings regarding the Prototipo wheels? Specifically, flat vs. "slight dish"?
    Are the ones commonly available through Pelican, etc. the "slight dish"? Is there an older "flat" version of the Prototipo made by Momo?
    Ah yes, and pics of that beautiful car with your recently acquired "flat" wheel.
    Henry Garazo
    '68 Polo Red 911L Barn Find
    '70T 2.7 Coupe
    '58 1600S T2-A Speedster
    '87 Triple Black Carrera Coupe
    "Form Follows Function"
    Early 911S Registry #962
    Potomac Region PCA
    Mar 2006
    Solana Beach, CA
    thanks Bob. I am actually planning to send my 380 to Tony shortly. I will give your "fine tuning" a try and keep my eyes open for the other size bell shaped hub. I believe Classico Wheels might be a source.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
  1. Vintage Momo Steering Wheel Question, Identify this wheel
    By rennwagen in forum Technical Info
    Last Post: 08-28-2012, 04:25 PM
  2. SWB steering wheel question
    By buddeman in forum Technical Info
    Last Post: 12-03-2009, 09:49 AM
  3. Steering Wheel P/N Question - Help Me ID
    By t6dpilot in forum General Info
    Last Post: 11-05-2008, 10:38 AM
  4. GT steering wheel question
    By 66S in forum General Info
    Last Post: 09-09-2008, 04:39 PM
  5. Another Steering Wheel Question
    By joe912 in forum Technical Info
    Last Post: 01-13-2005, 06:08 PM
