Thread: separating door window from metal channel
    Dec 2004
    SE Michigan
    How do I safely remove the door window from the window bracket (that is connected to the window regulator)? There's a folded rubber strip between the glass and channel that seems to have a death grip on the glass after ~35 yrs. Obviously, I don't want to break the glass. Thanks.
    Bill G.
    EarlyS #718 | RGruppe #437
    Hello there.
    I just soak in a solvent...gasoline etc..
    Kind regards
    Bill-
    I use a thin blade knife to slice along the glass on both sides. After a few passes, the sticky rubber seal will give up.
    It also helps to do it out in the sun where all parts get warmed up.
    Mike B.
    1972 911E #414
    Early S #1065
    When I did it some time ago I used a razor, lots of 3M adhesive remover to soften up the glue, and a screwdriver underneath to gently pry it up. I will say that unless you want to replace the glass, which i assume you do, I would leave it alone.
    Good luck,
    Early S Registry #630
    71 911S Irish Green
    65 911 #301826, Silver
    57 Speedster #83702 Aquamarine Blue
    Dec 2004
    SE Michigan
    Thank you, gentlemen, I will give it a try...
    Bill G.
  1. WTB: Aluminum U channel material for 69-73 door pockets
    By Perry911 in forum For Sale: 911 Parts
    Last Post: 01-05-2014, 02:13 AM
  2. FS: Window Channel
    By cjtbt in forum For Sale: 911 Parts
    Last Post: 11-19-2013, 06:37 AM
  3. Door widow channel felt one piece? Where to buy?
    By emnemn in forum General Info
    Last Post: 08-11-2013, 10:40 AM
  4. door window trim help for longnoses please, what metal?
    By haycait911 in forum Technical Info
    Last Post: 02-14-2011, 12:20 AM
  5. HELP! Separating engine from tranny
    By Aircool in forum Technical Info
    Last Post: 04-23-2006, 05:53 PM
