Results 1 to 2 of 2
Thread: Speedo Drive Tool
    Nov 2003
    Northern FL
    Speedo Drive Tool
    The speedo drive, off the transmission, on my 69 (901 transmission) has loosen up and needs to be tightened but a normal wrench won't fit. Looks like a 24MM. Crowsfoot is too fat because the hex is recessed...very little side clearance. Any advice as to what tool would work and where I can find it would be welcome.
    Two ways you can do this, use a small flat chisel and catch one of the flats and tap it in the direction to tighten with a small hammer, doesn't have to be real tight, you're not going to butcher it, second method, support front of trans with a jack stand and remove the trans mount, much better access, can use box end wrench.
  1. FS: 911 250KMH Speedo Mechanical drive
    By Strudelwagon in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-05-2014, 07:42 PM
  2. In the middle of a job speedo drive question
    By Rich Lambert in forum Technical Info
    Last Post: 04-10-2013, 09:47 AM
  3. Speedo Drive Boot Equivilent VW?
    By xpensivewino in forum Technical Info
    Last Post: 12-12-2012, 10:10 AM
  4. FS: NOS speedo angle drive
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2012, 08:17 PM
  5. NOS speedo angle drive for 901 tranny
    Last Post: 11-30-2010, 03:14 PM
