Thread: Front Spoiler No Ducktail Effects
    After seeing that sweeet Irish Green RS with no ducktail, I got to thinking Is there any negatives to running a spoiler be it RS or S, without a rear spoiler. I am aware and have felt the instability of running the oppisite, rear duck and standard front, highly NOT recomended but don't remember hearing any negatives with the Irish Green RS setup?
    Thanks in advance for your input and I expect to get it for the thinking comment.
    Rick
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Nope Rick... no problem
    That's the they were raced from late '71 through late '72...
    You'll just be just hang'n on a little tighter at the other end of 5th gear ...
    Cheers,
    Jan 2003
    London
    No problem...and yes they do wander about at the top end...it begins to get interesting around 120mph....
    Yep, my 73S with a duc droped at about 75 then a definate down force at 90. I guess what I'm afraid of is lift in the rear. Maybe those muffler skirts did serve a aero purpose. Naaahh.
    Rick
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Rick: It will be no problem at all. It will be a little tail happy in high speed turns just like any of the non tailed cars. If you put some rake in the car about 1.5 degrees measured at the door opening then it works great. The front RS or S spoiler will spill some of the air from going under the car which helps with the downforce. If you only use the tail it gives the rear downforce which gives the front lift and when the air gets under the front-more lift. You can also the lower the car to stop the air from going under the car. Hope this helps. Are you doing historic racing perhaps? Thanks Eric
    I am starting a 67 Normale project. I want to keep it slim and light. The budget and my driving skills will keep me out competitively but hope to zing around and stay out of everyones way. I have almost all the parts to build two seperatate motors, a high compression 2.4 and 2.7. I also can go the 2.5 short stroke route with a 3rd engine but want to run it on the street so will probably stay away from it for now.
    Rick
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
  1. Replies: 7
    Last Post: 07-20-2013, 05:50 AM
  2. front spoiler on 73 S
    By cmcfaul in forum Technical Info
    Last Post: 11-09-2012, 03:59 PM
  3. FS Ducktail Spoiler FG
    By Bobby Smith in forum For Sale: 911 Parts
    Last Post: 10-18-2011, 03:19 PM
  4. WTB: '72 - '73 Front S Spoiler
    By prez! in forum For Sale: 911 Parts
    Last Post: 04-03-2011, 04:06 PM
  5. S front spoiler
    By 911quest in forum General Info
    Last Post: 07-18-2007, 07:16 AM
