Thread: spark plugs: replace or clean?
    Mar 2005
    I think I have at least one fouled spark plug. Is it possible to fix this by
    removing the plug and just cleaning it?
    Yup; if they aren't old, just clean them up.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    I agree with Kenikh. But I have had a couple of instances where it was gas fouled and caused a miss. You may have a bad wire or if running carbs a air correction nozzle plugged or if it's two plugs next to each other then an incorrect float, either sinking or not adjusted. Basically you need to track down the cause of the fouling.
    Rick
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Mar 2005
    I tried to clean them but was unhappy with the result. I was able to get 6 new plugs from Pep Boys for about 6 dollars!
    Don
    Senior Member 72911E's Avatar
    Jul 2006
    London / Fort Lauderdale
    I went to order spark plugs for my '72 car yesterday. I was advised they were $13.85 each. Some special plug was needed??!!
    When they cross referenced it to a NGK, there was a plug for a couple of bucks.
    What plugs do people use? My car is 72 2.4E (mechanical fuel injection)
    Also, was also quoted $60 for a fuel filter! Is this correct?
    Derek
  1. 2.2 spark plugs
    By TZombek in forum Technical Info
    Last Post: 11-27-2012, 11:43 AM
  2. 73 S spark plugs
    By philip guiral in forum Technical Info
    Last Post: 03-03-2010, 07:03 AM
  3. Spark Plugs Help
    By denson in forum General Info
    Last Post: 09-13-2008, 04:28 AM
  4. Spark plugs---which?
    By Zeke in forum Technical Info
    Last Post: 02-16-2004, 09:18 PM
  5. '73 S spark plugs
    By Plays with Cars in forum Technical Info
    Last Post: 05-22-2002, 12:52 PM
