Thread: WTB or WTT: good distributor for 2.4T motor
    Looking for useable 2.4T distributor for the motor I'm putting in my '69 911T. Will also trade a perfectly operating 2.0 T dizzy for it. I bought this one new, and have not driven the car more than a couple thousand miles with it.
    Thanks!
    Zach Mayne
    1969 911T, 1988 924S, 1985 635CSi, some Alfas and a Fiat....
    Are you looking for a 73.5 CIS dizzy? If so, I may have one - just nee d to check it out.
    Jim
    I'm actually using the Webers from the 2.0-liter. Will a CIS distributor work with Webers? I'm not sure if the motor was originally CIS or MFI.
    Zach
    Zach Mayne
    You can tell if your engine was MFI by checking the driver's side cam end at the firewall. If it was MFI, there will be a gear there to drive a toothed belt for the MFI pump. Carb and CIS cars don't have this. Hope this helps you find the right distributor.
    Hello: I will look today for a 2.4 T distributor that will work with your Weber carbs. Thanks Eric
    Bosch 2.4 T factory distributor.
    Hello: I found one for your 2.4 T. It is in great condition and ready to go. Make me an offer for it since I don't need your T distributor. It is a large hole distributor, make sure your need this one. Thanks Eric
  1. FS: distributor out of 69S motor
    Last Post: 02-12-2013, 08:46 PM
  2. WTB distributor for 911T 1969 (2.0 motor)
    By Cdomingos170 in forum For Sale: 911 Parts
    Last Post: 06-03-2012, 09:12 AM
  3. FS: 1972 "T" Marelli Distributor with very good cap & rotor - $125
    By K-squared in forum For Sale: 911 Parts
    Last Post: 07-27-2009, 10:40 AM
  4. WTB: Good rebuildable cast iron distributor 231159001
    Last Post: 12-03-2008, 08:25 PM
  5. Replies: 2
    Last Post: 12-04-2006, 07:59 AM
