Was someone making these that worked with the standard grills? Anyone have a source?
Cheers, Ryan
Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
Dave at M&S racing sells them on ebay $99.00Originally Posted by obrut
Mike
S Registry #825
73.5 Dalmatian Blue
Or you can make them for $1 by bending and drilling aluminum bar from Home Depot.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
Man after my own heart!
Michael
-Dusty 70S Coupe
-S Registry #586
kenik,
you wouldn't happen to have a pic or two of the finished product lying around would you?
Cheers, Ryan
No, but Michael does.
Kenik
- 1969 911S
- 1965/66 911
- S Reg #760
- RGruppe #389
The two on the outside are OEM. The inners are repops. The metal is a bit thicker and the bends are just a little off but they can be made to work.
It only takes these things to be off a hair to create a bind when you re-mount your grills.
The light hardware is shown in the last photo.
In all honesty you should be able to knock a set off easily if you have access to a break but it never hurts to support your vendors.
Tom
Early S Registry #235
rgruppe #111
I bought a pair from Mike Swanson/AR Concepts that look exactly like the repros shown above, probably his work too. Great craftsmanship. $50 or so.
If you go the Home Depot route, make sure to tap the smaller holes (where the brackets mount to the battery boxes); that way only a bolt and lockwasher are required to secure it from the inside. You do not want to try and put a nut on the other side, there is zero room.
While we're on the subject, anyone have a driver's side chrome (69-72) horn grill I can cut up for my lights?
BA
Brad Anderson
911 1970 einspritzung Karmann coupe 0012
Some kind of happiness is measured out in miles
thanks guys.
i'll also add two more images i found whilst doing some further searching - in case others find them helpful in the future.
Cheers, Ryan
Originally Posted by sithot
Is the nut welded to the bracket half? Also, I 've never seen the sleeve before. Is that correct? I don't recall seeing that on any setups or in the parts manual. Any pics with the lights installed with the sleeve? Curious how far out that puts the lights.
Michael
-Dusty 70S Coupe
-S Registry #586
