Results 1 to 2 of 2
Thread: Difference between 911/93 & 911/83 engine
    What are the main differences between 911/83 & 911/93 engines? If my ustanding is correct, 911/83 are RS engines?
    Is it possible to to convert a 911/93 engine to an RS spec'd engine and if so, what are needs to be done for the conversion?
    And lastly, how reliable is an RS engine (as compared to 911/93 engine)
    Thanks for your help
    993C4 Cab
    Oct 2005
    Minneapolis, MN
    The main differences are the pistons, cams and the heads on the 911/83 have a threaded hole for the MFI fuel injector.
    Otherwise.......the valves are the same size and intake port on the RS engine is only 1 mm larger. They are both 8.5:1 and 2.7L
    RS engines run much stronger than the CIS 2.7 and yet are perfectly reliable......all things considered.
    I hope this helps.
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
  1. What's the difference ? 73 TE & 73 T ?
    By LV911 in forum General Info
    Last Post: 07-27-2013, 08:41 AM
  2. SSI difference
    By StephenAcworth in forum Technical Info
    Last Post: 05-30-2013, 07:44 PM
  3. What is the difference btwn. 901/02 & 901/26
    By gtgroupe3 in forum Technical Info
    Last Post: 05-14-2008, 02:14 PM
  4. 911S 66 vs 67 is there a difference?
    By preS in forum Technical Info
    Last Post: 02-28-2008, 04:17 AM
  5. Difference between 73 and 73.5 911?
    By TMWillett in forum Technical Info
    Last Post: 05-04-2005, 02:02 PM
