Thread: New Motor, new heat exchangers - car still stinks
    Nov 2002
    Worshington State
    I had counted on losing the oily fumes from the heater when I replaced the motor and heat exchangers. The oily smell gives me a headache on long drives and permeates the car and my clothes. Can so much residual oily residue live in the heating ducts to still create this problem or am I looking at something more profound?
    Hello: Make sure the heater control valves are working correctly and the valve is closing off. The cloth on the inside sometimes disolves and allows the oil smoke in. Also if you have an oil leak on top of the engine it will blow through the heater system as well. Check around the vent cover area. Good luck. Thanks Eric
    FWIW, when Bernie cleaned my car up, the burning oil smell went away.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Nov 2002
    Worshington State
    Eric,
    Where are the heater control valves located so I can inspect?
    Rick
    Kenik - Bernie is across the river from me (literally), so if all else fails...
    Rick: The control valves are mounted to the body above the heat exchangers on the front sideof the exchangers. They are held on with 3 nuts and the activating cable. Hope this helps. Thanks Eric
    Nov 2002
    Worshington State
    Eric,
    Thanks for the tips.
    Rick
  1. WTB: MFI Heat Exchangers
    By hwgunner in forum For Sale: 911 Parts
    Last Post: 10-29-2013, 01:11 PM
  2. FS: MFI SSI heat exchangers
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 06-27-2013, 10:09 AM
  3. wtb - heat exchangers for 66' 911
    By vintage83 in forum For Sale: 911 Parts
    Last Post: 08-07-2008, 12:13 PM
