69 Manual says tank capacity is 16 gallons w/ 1.5 in reserve. The PO had tank replaced due to rust and when my guage is resting on "E", the most I ever can put in is 12.5 gallons.
Are replacement tanks smaller? or is my sending unit miscalibrated?
Joe
'69 E Targa "Roxie"
Early S #937
subscribe please
Joe
'69 E Targa "Roxie"
Early S #937
I'm not an expert on fuel tank sizes, but I do not think there are tanks that takes as little as 12.5 imp gallons. I have, however, experienced fuel gauges that are not accurate. Most likely the tank unit.
Bring some extra fuel and run the tank dry.
Sigurd
Member # 1200
73.5 T
US gallon and UK gallon is not the same meassurement:
U.S. liquid gallon is 231 in³ (exactly) or 128 U.S. fluid ounce (exactly) or 3.785411784 liters
U.S. dry gallon 4.404 884 L
Imperial (UK) gallon is 160 imperial fluid ounces (exactly), or 4.54609 L (legally). That is approximately 1.201 US gallons.
Is this the problem?
Early 911S Registry #931
1971 911 2.2T Coupe Tangerine
Mine's 20+
$55 clams to fill up yesterday.
(SC tank)
Eric - Sandy, Utah
71 911
914-6/GT
914-6/ORV
87 944 Spec 1
Porsche Truck
62 Beetle
80 VW “Caddy” Pickup
72 R75/5 Toaster Tank
PMB Performance
Love Us On Facebook
All my manuals say 16.4 US Gallons.
Citation F1000 on the way
Other Early 911/912/914
I recently looked into replacing my gas tank with a later larger tank and read that 74-83 21.2 gallons and 84+ 22.5 gallons. Assume 65-73 is 16 or slightly larger as roblav mentioned.
_B
Sent from a pay phone
888888 eL, Oph'eL'ia
Instagram: werk_crew
www.werkcrew.com
www.werkcrew.tumblr.com
www.handofwinter.tumblr.com
R.A.O.P.
(resurrecting an old post), can one just swap tanks? put in a larger tank from a later model? ideally best solution is to get atl or fuelcell make you a vintage cell with bladder. but upgrading fuel tank size, is this also a viable option? for a longhood?
'72T Coupe - Sepia Brown
You can put in the larger tank from a big bumper car, there is slight difference in vent tube diameter and location, and you'll need to go to a space saver spare. Seems like there is also some difference in fuel fittings at bottom, can't remember exactly what though.
My 71 car was up dated too a late SC fuel tank. Close to 25 Gallons a bit more than 345 miles per tank at 85 mph . Was great running from Northern Michigan to Cincinnati Ohio, Round trip on less than 2 1/2 tanks. There were only two draw backs. Firts was the cost on a top off, second was when running with other Long hoods was the short stopping for fill ups. If I remeber right it was pretty much a drop in and yes I did have to go to a space saver and a Porsche air compressor. The same SC provided all the needed parts for the converssion.
Bill Barnich
R Gruppe Nr.230
Early S Nr.960
71 911T/2.7 Tangarine
73 911?/3.6 work in progress
