Thread: Fan shroud hardware question
    I am finishing up all the little pieces to make up a complete hardware kit for the 65-73 model fan shrouds. I just wanted to verify if all the fasteners are supposed to be yellow zinc. Specifically, the 6 M6 hex-head sheet metal screws that go on the front part of the shroud to hold the air ducts in place. These are seemingly unavailable, except in clear (silver) zinc and it looks like I will have to get them plated.
    It is also a bit unclear as to which rubber grommets, rubber plugs and plastic plugs went on the different years. The PET disc is not clear, the parts books are the same and I only have my '67 coupe to look at for accuracy.
    Any feedback on "correctness" would be greatly appreciated. We have standards to uphold!
    Will, where in Pasadena is your shop?
    J-P
    ______________
    S Registry #949
    Actually, I live in Pasadena but the shop is in Arcadia. Give us a call at 626 445-0108.
    Is it "yellow zinc"?...or cadmium?
    Peter Kane
    '72 911S Targa
    These were originally yellow cadmium.
    If you are going to get them plated I would recommend yellow zinc. It is better for the environment, your own health, and lasts longer.
    That being said it looks slightly different but so be it.
    1970 911S Targa
    On the road again soon.
  1. 70-71 seat mounting hardware finish question
    By TZombek in forum Technical Info
    Last Post: 04-15-2013, 04:57 PM
  2. Early shroud question...
    By speedo in forum General Info
    Last Post: 11-26-2012, 05:40 PM
  3. Fender Mounting Hardware Question
    By John912 in forum Technical Info
    Last Post: 06-30-2011, 08:42 AM
  4. Fender hardware mounting question
    By neilk in forum Technical Info
    Last Post: 01-30-2005, 06:11 PM
  5. 2.2S shroud question
    By fryardds in forum Technical Info
    Last Post: 04-01-2004, 04:44 PM
