Thread: Koni dilemma !!!
Threaded View
    Koni dilemma !!!
    OK, I thought I've read all about this on this board and Pelican's but ... I've run into something that's baffling me...
    After having them replaced by the second owner in 1986 I fingered it was time to put new shocks on the old blue car...
    The car came with the S Koni option ... so instead of changing to Bilstein struts I thought I'd stick with Koni and go with the 'new' gas sport yellow shocks. After looking in the Performance catalog I ordered what I thought was the right pair and Richard and I dug into the job. The rears were no problem, however when it was time to install the fronts we came up against a crazy mismatch...The old and new top retaining cap nut were completely different...
    The rough dimensions are:
    Old nut
    Total thread dim. - 52.8mm
    new - 50.0mm
    Thread - fine
    new - course
    Thread depth - 9.5mm
    new 7.5mm
    Inside cup dim - 36mm
    new - 39mm
    Performance does not seem to have have a cup that I can adapt...
    It would seem that if I increased the old cup dim. by 3mm and reused it I could get away with the install ...
    I would post a picture but there something wrong with the board right now...
    Where's Jason from Paragon when you need him...
    Help
  1. Fuel Filter Dilemma
    By Red69T in forum Technical Info
    Last Post: 04-20-2013, 12:54 PM
  2. Tire and Rim size dilemma
    By A.T. in forum Technical Info
    Last Post: 04-14-2012, 08:43 PM
  3. Dilemma on restoring interiors
    By jaldeguer in forum General Info
    Last Post: 11-12-2011, 04:32 AM
  4. Door Dilemma
    By mhackney in forum Technical Info
    Last Post: 05-05-2008, 10:46 AM
  5. Dilemma - What seats to get ??
    By CanuckRS in forum General Info
    Last Post: 12-17-2007, 10:54 AM
