Results 1 to 2 of 2
Thread: SWB Fuel Tank
    Jun 2003
    Bend, Oregon
    SWB Fuel Tank
    Are there any differences between the stock fuel tanks used in SWB and those used in LWB cars?
    Senior Member Grady Clay's Avatar
    Sep 2004
    Unincorporated Arapahoe County, Colorado, USA
    John,
    Basically no. The standard fuel tanks are essentially the same ’65-’73. There are some subtle detail differences and finishes. These tanks have three fittings facing the rear (drain plug, fuel fitting with screen filter and one plugged (unless fitted with an auxiliary gasoline heater). The MFI fuel return is to the drain plug opening with a banjo. The first significant change comes with the ’73.5 911T CIS with an internal “swirl pot” and baffles. Next is in ’74 with the larger standard tank requiring the space-saver spare. With fuel line fitting differences, the tanks stay pretty much the same through ’89. These tanks have the fuel fittings (pipes) at the rear. The drain/screen filter access is at the bottom center of the tanks.
    The ’65-’73 tanks are 62 Liters and the ’74-’89 are 80 Liters. There are larger optional or race fuel tanks of 100 and 120 Liters in both steel and plastic. Some are center-fill. All the larger tanks take a different (longer) fuel level sender if you want it to read full range to empty.
    With only adapting the fuel lines, all tanks are interchangeable ’65-’89.
    Of course there is more detail and there are exceptions.
    Best,
    Grady
  1. FS: SC oem fuel tank and early 65 fuel tank
    By EARLY911ZOO in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-17-2013, 05:27 AM
  2. FS: 30 + gal fuel tank 911
    By georgepvalerio in forum For Sale: 911 Parts
    Last Post: 07-23-2012, 09:25 AM
  3. WTB Fuel Sender for 100L fuel tank
    By jimf42 in forum For Sale: 911 Parts
    Last Post: 09-05-2010, 12:40 PM
  4. WTB - NOS Oem fuel tank for 65-66 swb 911
    By Baron in forum For Sale: 911 Parts
    Last Post: 03-22-2008, 03:40 PM
  5. Which fuel tank is this ?
    By Porsche-RSR in forum General Info
    Last Post: 04-01-2007, 09:56 AM
