Results 1 to 10 of 11
Thread: better base for 911R Replica
    Hello,
    I'd like to know what is the best to make a 911R replica.
    An early 2.0l from 1965, or a 1972's one because the existing oil filler already existing.
    I have the possibilty to buy the first one but considering that i'm racing a little bit in french club, i think that the second one is the best for the quality of driving,
    Thanks in advance.
    Freddy
    Freddy,
    For authenticity, a short wheelbase car would be more appropriate for a 911R or T/R ...
    However the factory did produce a 'lightweight' version of the long wheelbase cars from '69 up to the time they evolved into the S/T's which starting around late '70 through '72...
    So.... for the look, it's kind'a up to you... the '72's oil filler is a nice touch
    BTW - I have seen more and more 911 'hot rod' projects start with '69's (lightest standard LWB chassis) and '69 912's (lighter yet)
    As far as drivability - They are both great in there own ways...
    The world is your oyster...
    Hope any of this helps,
    Cheers,
    I always thought that a 68 was the perfect base for an R replica because of the gauges and break away style rear view mirror. I forget but I believe Ernie once told me a 68 912 for some reason.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Bob's right.
    A 68 912 would be the best way to go.
    Since the real 911R was built on the 68 911/912 base, you are starting with the real deal. A 912 is best because you can pick up a nice clean one much cheaper than a 68 911. Since it is going to be heavily modified when you are done with it, why not start out the project cheaper with a car that costs $5-10k, rather than one which cost $12-20k?!
    Feb 2003
    Los Angeles
    Weight?
    My references list the 1969 - '71 911's as 2249 lbs. The 1972 - '73 as 2310 lbs.
    Does anyone know the weights of the following?
    1967 911 & 912
    1968 911 & 912
    1969 911 & 912 (I think my 1969 reference is incorrect. I have also heard that the 1969 was the lightest chassis)
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Hello: I have heard that the 70 model is the lightest with it's aluminum rear bumper section and engine lid. The 69 is next with Webers so the T is lighter than the E or S. The non sport seat cars are lighter as well. It also depends on how much undercoating and interior sound proofing was installed. The 912's are getting more expensive since the historic race guys are buying them for 911 race cars. I would do a long wheelbase car and add the 993 oil tank with the filler cap added. That gives you more cars to choose from. If you do a early short wheelbase car then you will have to weld on some flares to make it look right. Hope this helps. Thanks Eric
    My references list the following weights
    66-68 912 995 Kg
    67 911 1080
    69 911T, E 1020
    69 S 995
    70-71 911 1020
    72-73 911T 1050
    73 E, S 1075
    Not sure that all makes makes sence. The important question would be what does the chassis weigh w/o engine and tranny, one would think if chassis were similarly equiped there would be little difference.
    Phil
    I have heard that the Karman bodied 69-71 were the lightest 911's as well being a little more rare. Has anybody else heard of this also?
    Bill
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
    Hello: Yes the Karman bodies are the lightest. I have three cars with Karman bodies a 69 E and 70 E lastly a 70 S. The 69 did weight less than another 69 S. I still need to weight the 70 S someday. Thanks Eric
    How many pounds lighter?
  1. 911R replica on Hemmings
    By scargo69s in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-23-2011, 02:03 PM
  2. 911R Replica Steering Wheel
    By NTW in forum For Sale: 911 Parts
    Last Post: 12-04-2007, 09:01 AM
  3. '67 Porsche 912 roller, good 911R base, $2900 SoCal
    By 911E4ME in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-15-2007, 04:40 PM
  4. 912 karmann as 911R replica base
    By ydderf911 in forum Technical Info
    Last Post: 10-08-2007, 11:44 AM
