Results 1 to 10 of 19
Thread: Repairing Kienzle Clock
    I have aquired a proper Kienzle Clock for my car.
    As expected it did not operate.
    Does anyone know where to send these for repair?
    North Hollywood cannot repair these. They convert them to quartz. I realize this would be more reliable but then I may as well stick with the one I have.
    I would like to repair the original
    Thanks in advance.
    Bob
    1970 911S Targa
    On the road again soon.
    Hi Bob,
    I don't know if you've seen these articles but just in case...
    http://www.pelicanparts.com/techarti...ock_repair.htm
    http://www.pelicanparts.com/techarti...ck_repair2.htm
    Bobby
    71' Olive 2.2E Targa / Early S #491
    I've always considered the glass to be half full...that is until I reached middle age and realized that it is actually half empty.
    Crap, I have had too many Guinness tonight and can't read these articles properly. I'll have to read them in the morning.
    Thanks Bobby.
    1970 911S Targa
    When you've sobered up and read the articles, and you open up the clock, if you need some low-temp solder, I'll send you some. You don't need much.
    Tyson
    Early 911S Registry #472
    1968 S - #477
    Mostly Stock
    My clock is beyond repair without new parts.
    The rewind pawl is warn out and the points leaf spring is cracked.
    Time to find another.
    Thanks guys.
    1970 911S Targa
    Bob, I've got I'm willing to let go.
    PM me, please.
    Tyson
    1968 S - #477
    Mostly Stock
    Mar 2004
    Castro Valley, Ca.
    hi Bob;
    (and anyone else wondering what to do with a mechanical clock that does not run)
    typically what happens w/ these is during a time of long sitting the voltage in the battery drops to the point that it will no longer energize the movement.
    instead of buring up the coil there is a solder "fuse" that let's go. this can usually be remedied but applying heat to the joint. a small 'pencil' (37 watt) iron is best, but the larger "gun" will work if you're careful.
    additionally, keep in mind that mechanical clocks need to be cleaned and lubed every 10 years or so. any competent clock maker should be able to handle this chore. if parts are required that's where the job gets sticky. bushings can easily be turned on a bench lathe, but after that you're looking for a donor or another unit. i have a local guy that does a CLA for $25.
    HTH
    best
    jerry
    Hi Guys,
    Thanks for your help. I was able to find another clock to use the electromagnet rewind assembly out of. I do need to get some of the 250F solder but the clock has operated for days now without missing a minute!
    I think I may have found a new hobby
    Bob
    1970 911S Targa
    Junior Member
    Apr 2003
    Sugar Land, TX
    Tyson,
    Where can the low-temp solder be found? I've been searching the internet, but have not found a source.
    Roy
    Member Hugh Lindberg's Avatar
    Nov 2010
    Houston / Brenham, TX
    Hi - I'm trying to repair my clock and am also looking for low temp solder. Tough to find locally or on the web, so far. Any leads would be very much appreciated. Thanks....
    Hugh Lindberg
    1972 911T
    1965 Alfa Romeo Giulia Sprint GT
    1970 Alfa Romeo GT Jr
    ESR #2501
  1. Replies: 15
    Last Post: 02-10-2015, 12:14 PM
  2. Repairing/Restoring Undercoating
    By bburcha in forum Technical Info
    Last Post: 11-14-2008, 05:58 AM
  3. WTB: Kienzle VDO Clock (non-working or parts)
    By jcarpio in forum For Sale: 911 Parts
    Last Post: 05-11-2008, 11:05 AM
  4. Repairing an S Tub
    By monza in forum Technical Info
    Last Post: 08-04-2006, 09:19 PM
