Thread: Shift seal change w/o dropping engine?
    Dec 2004
    Can the shift seal just behind the tunnel be switched without having to drop the engine? A buddy wants to know if he can disconnect the shift linkage, pull the old seal, and replace it without having to go through the extra steps of dropping the engine. The car is an '80 911 SC.
    I'd welcome any information I can pass along.
    Thanks!
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Hello: Yes you can change the shift rod seal in the car. Just be careful when removing the old seal. Thanks Eric
    I had to do this. And I will be honest it was a pain in the ass. In fact it
    was a terrible job and I would up replacing it at the Shop when they had the motor out a year later.
    Make a PVC pipe to fit over the shaft with the seal and smooth the edge use the to press the seal into the shaft. Make Sure to geT ALL the remnants of hte old seal out. Grease the new seal good and use pipe to press it in.
    Good Luck
    JW
    Dec 2004
    Thank you gentlemen!
    I'll pass along the information AND a good dose of caution as well.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
  1. 1967/1968 engine lid change
    By mpotvin in forum General Info
    Last Post: 08-02-2012, 07:10 PM
  2. MFI dropping a cylinder
    By Strato 102 in forum Technical Info
    Last Post: 11-04-2010, 08:18 PM
  3. Engine lid seal
    By Paul Schooley in forum General Info
    Last Post: 05-13-2010, 04:44 AM
  4. Engine re-seal: What to use on seals?
    By Aircool in forum Technical Info
    Last Post: 05-01-2006, 06:29 PM
  5. Tweeks Dropping Porsche Parts
    By CurtEgerer in forum Off Topic
    Last Post: 04-21-2006, 11:38 AM
