Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: 2.4 with 5R and 7R cases
    I was just looking over a 911 and noticed the cases on the motor are different. One side a 5R and the other 7R. Is this a common thing to see? The story is the motor was rebuilt and Balanced/Blueprinted.
    Any comments on this . . . doesn't look right to my untrained eye.
    Tom
    Jul 2005
    Atlanta, GA
    5R and 7R
    There was an earlier thread on this around December 2005...the consensus was that Porsche would occassionally mix case halves when they were upgrading case designs in order to use up the existing stock. So you could find a 3R/4R engine, a 4R/5R, or a 5R/7R (there was no 6R).
    The original case on my 12/72 build date 1973E is a 7R/7R, and it has not been apart. I have not been able to confirm definitively when Porsche stopped using the 5R cases - most people think it was in the early spring of '73.
    What is the build date on the car (on the driver's door jamb sticker?
    1973 911E - Viper Green
    1973 911T - Light Ivory, becoming Glacier Blue RS
    My build dat is 12/72. Was there any major difference between the 5R/7R cases? I'm guessing they were certainly compatible . . . of course matching cases would be "best" but does it really matter?
    Thanks for the reply . . .
    Tom
    Jul 2005
    Atlanta, GA
    5R vs 7R Case
    The 7R cases are much preferred due to additional reinforcement webbing that reduces the case flexing and resultant oil leaks and internal wear. However, for a relatively unstressed engine (moderate RPM, moderate compression, less than 210 operating oil temps) it shouldn't make that much difference.
    I have seen some 1R/2R case combos, so the 5R/7R mating doesn't seem too odd.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    I've never seen a 5R/7R from the factory.
    Every 2.4 I've looked at over the past 30 years has been either a 4R/5R or 7R (both sides) case.
    Just for grins, I would carefully inspect the case # and the type # as those are stamped on each side of the case, respectively, to see if the numbers jive with each other. That will validate whether these were matched at Porsche or during a subsequent repair.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Jan 2003
    NW Indiana
    Steve,
    When my RS case returned from C.E. (machine shop) the mechanic showed me a stamped 2 digit # on each case halve that match to confirm the case halves match. This was different than the type # and I seem to remember they are stamped on the bottom of the case along the seam. Is that correct?
    Brian
    '71T
    R Gruppe #299
    Hi Brian:
    Hmmm,..I'm going to go have a look,..
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    OT but what did the 3R cases hold? i was told early 2.4?
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Jul 2005
    Atlanta, GA
    5R/7R Case
    I defer to Steve's experienced opinion here....
  1. FS: Engine cases
    By cjtbt in forum For Sale: 911 Parts
    Last Post: 02-16-2014, 05:48 AM
  2. Engines/cases available
    By Frank Beck in forum General Info
    Last Post: 05-11-2013, 04:43 PM
  3. 7R mag cases
    By beginner in forum Technical Info
    Last Post: 04-13-2003, 03:19 PM
  4. 7R cases
    By Jim Schrager in forum Technical Info
    Last Post: 09-18-2002, 07:59 PM
